HA-2840 pdf datasheet(600MHz,
消耗积分:2 | 格式:rar | 大小:336 | 2009-01-06
刘洋
分享资料个
The HA-2840 is a wideband, very high slew rate, operational
amplifier featuring superior speed and bandwidth
characteristics. Bipolar construction, coupled with dielectric
isolation, delivers outstanding performance in circuits with a
closed loop gain of 10 or greater.
A 625V/μs slew rate and a 600MHz gain bandwidth product
ensure high performance in video and RF amplifier designs.
Differential gain and phase are a low 0.03% and 0.03
degrees respectively, making the HA-2840 ideal for video
applications. A full ±10V output swing, high open loop gain,
and outstanding AC parameters, make the HA-2840 an
excellent choice for high speed Data Acquisition Systems.
The HA-2840 is available in commercial and industrial
temperature ranges, and a choice of packages. See the
“Ordering Information” below for more information. For
military grade product, refer to the HA-2840/883 data sheet.
评论(0)
发评论
下载排行榜
