HA-2539 pdf datasheet (600MHz,
消耗积分:3 | 格式:rar | 大小:226 | 2009-01-07
分享资料个
The Intersil HA-2539 represents the ultimate in high slew
rate, wideband, monolithic operational amplifiers. It has
been designed and constructed with the Intersil High
Frequency Bipolar Dielectric Isolation process and features
dynamic parameters never before available from a truly
differential device.
With a 600V/μs slew rate and a 600MHz gain bandwidth
product, the HA-2539 is ideally suited for use in video and
RF amplifier designs, in closed loop gains of 10 or greater.
Full ±10V swing coupled with outstanding AC parameters
and complemented by high open loop gain makes the
devices useful in high speed data acquisition systems.
For further design assistance please refer to Application Note
AN541 (Using the HA-2539 Very High Slew Rate Wideband
Operational Amplifiers) and Application Note AN556 (Thermal
Safe-Operating-Areas For High Current Operational Amplifiers.
For military grade product information, the HA-2539/883 data
sheet is available upon request.
评论(0)
发评论
下载排行榜
