HS-26CT32RH pdf datasheet (Rad
消耗积分:3 | 格式:rar | 大小:343 | 2009-01-08
李明
分享资料个
The Intersil HS-26CT32RH is a differential line receiver
designed for digital data transmission over balanced lines
and meets the requirements of EIA standard RS-422.
Radiation hardened CMOS processing assures low power
consumption, high speed, and reliable operation in the most
severe radiation environments.
The HS-26CT32RH has an input sensitivity typically of
200mV over the common mode input voltage range of ±7V.
The receivers are also equipped with input fail safe circuitry,
which causes the outputs to go to a logic “1” when the inputs
are open. Enable and Disable functions are common to all
four receivers.
Specifications for Rad Hard QML devices are controlled by
the Defense Supply Center in Columbus (DSCC). The SMD
numbers listed in the “Ordering Information” must be used
when ordering.
Detailed Electrical Specifications for these devices are
contained in SMD 5962-95631. A “hot-link” is provided on
our homepage for downloading.
评论(0)
发评论
下载排行榜
