IPTV码流捕捉器/播放器 (IPTV Stream Cap
消耗积分:10 | 格式:rar | 大小:333 | 2009-01-15
分享资料个
IPTV Stream Capture & Playback(IPC500) is a professional and powerful solution adapting MPEG DTV signals for streaming across IP networks.
In a Lab environment, IPC500 is the most flexible solution for setting-up IPTV signal environment your engineers need.  With various Ethernet output interfaces, manufacturers can easily set up  manufacturing lines for IPTV and IP set-top box. With User-friendly configuration and GUI, user can control and test IPTV streaming with support for UDP.
评论(0)
发评论
下载排行榜
