EL2111 pdf datasheet (Low Cost
消耗积分:2 | 格式:rar | 大小:455 | 2009-01-17
李鸿洋
分享资料个
The EL2111 operational amplifier, built
using Elantec’s complementary bipolar
process, offers unprecedented high
frequency performance at a very low cost. It is suitable for
any application, such as consumer video, where traditional
DC performance specifications are of secondary importance
to the high frequency specifications. On a 5V supply at a
gain of +2 the EL2111 will drive a 150Ω load to +2V, with a
bandwidth of 100MHz. This device achieves 0.1dB
bandwidth at 5MHz.
The recommended power supply voltage is 5V. At zero and
5V supplies, the inputs will operate to ground. When the
outputs are at 0V the amplifier draws only 2.4mA of supply
current.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
