ISL98012 pdf datasheet (1.8V I
消耗积分:3 | 格式:rar | 大小:333 | 2009-01-19
王娟
分享资料个
1.8V Input PWM Step-Up Regulator
The ISL98012 is a high frequency, high efficiency step-up
DC/DC regulator operated in fixed frequency PWM mode.
With an integrated 1.4A MOSFET, it can deliver up to 600mA
output current at up to 92% efficiency. The adjustable
switching frequency is up to 750kHz, making it ideal for
common boost applications.
When shut down, it draws <1μA of current. This feature,
along with the minimum starting voltage of 1.8V, makes it
suitable for portable equipment powered by 1 Lithium Ion, 3
to 4 NiMH cells, or 2 cells of alkaline battery.
The ISL98012 is available in a 10 Ld MSOP package, with a
maximum height of 1.1mm. With proper external
components, the whole converter takes less than 0.25in2
PCB space.
This device is specified for operation over the full -40°C to
+85°C temperature range.
评论(0)
发评论
下载排行榜
