基于LT8570-1_Typical Application直流到直流多输出电源的参考设计1234
消耗积分:2 | 格式:pdf | 大小:884.97KB | 2021-07-13
王军
分享资料个
说明
  • Typical Application for LT8570EMS8E-1 1.2MHz Charge Pump Creates ±12V from a Single Lithium Ion Battery. The LT8570-1 is a PWM DC/DC converter. The LT8570-1 contains a 0.25A, 65V power switch. The LT8570-1 can be configured as either a boost, SEPIC or inverting converter
主要特色
  • Conversion Type
    DC to DC
  • Input Voltage
    2.6 to 5.5 V
  • Output Voltage
    ±12 V
  • Output Current
    0.04 A
评论(0)
发评论
下载排行榜
