MPEG-2 TS流播放器 FOR WIN32的程序源码vl
消耗积分:10 | 格式:rar | 大小:6744 | 2009-02-25
h1654155957.9921
分享资料个
Welcome to the VLC media player! VLC media player is a multi-purpose multimedia tool. It can play DVDs, VCDs or read a stream from the network. It plays DivX/MPEG-4 files (and many other files) and is unaffected by the dreaded .avi bug which can cause choppy sound when playing DivX in QuickTime Player. You can also stream content to the network or a file. But above all it is the ONLY media player on Mac OS X, which has support for multi-channel sound-output.
VLC media player was originally developed for GNU/Linux systems, but has been ported to numerous operating systems, including Mac OS X and Win32.
The following frequently asked questions are answered below :
1. How do I install ?
2. How do I use VLC media player ?
3. How do I read a CD/(S)VCD/DVD ?
4. The video is choppy! It's like we're dropping frames.
5. How do I remove VLC media player ?
6. Where can I find an older version for Mac OS 9 ?
7. How do I change the size of the video window ?
8. I think I found a bug. What should I do ?
9. Support for files with subtitles.
10. What do all the options in the preferences do ?
11. How do i get fullscreen video on my other monitor ?
12. Multiple sound-devices and multi-channel sound?
When you download VLC media player, you will end up with a VLC-0.7.x.dmg file. Double-click, or drop it on the application Disk Copy, to open this file. An icon will now appear on your Desktop, right beside your drive(s). Open it and drag the VLC application from the resulting window to the place where you want to install it. Most often this is the directory Applications on your main harddrive.
To use VLC media player, you will need to open the application first and then from the "File" menu open the file or disk, you would like to view. Double-clicking a file will result in QuickTime Player trying to open it. If you prefer you can change this by selecting your file and choosing "Get Info" from the "File" menu of the Finder. In the "Open With" section you can select VLC and if you check the checkbox, then all files of the type you have selected will be opened in VLC media player if you double-click them from that moment on.
评论(3)
发评论
kdsjkdaidh 2015-10-29
0 回复 举报
很好 收起回复
2011-04-26
10 回复 举报
谢谢分享! 收起回复
全部评论
下载排行榜
全部3条评论
