产品指标 |
CPU: LGA 1151 Intel® 6th/7th generation Core™ i7/i5/i3, Pentium® or Celeron® processor |
内存: 配置2槽独立 SO-DIMM DDR4 2133MHz内存,可扩展高达64GB |
硬盘: 2.5寸480G SSD SATA硬盘 |
显示接口: 1 x DVI-I(up to 2560x1200@60 Hz)外置 1 x HDMI 1.4 (up to 4096x2160@24Hz)外置 |
I/O接口: 1 x KB/MS (1x6 pin) 外置;2 x RS-232(DB9) 外置; 4 x USB 2.0 外置;4 x USB 3.0 外置; 1 x mSATA (SATA & USB signal) 内置; 4 x SATA 6Gb/s (RAID 0/1/5/10 supported) 内置; 1 x USB 2.0 (180° Type-A) 内置; 2 x RS-232/422/485 (2x5pin, P=2.54) 内置 |
音频: 3 x Audio jacks (line-out, line-in, mic-in) |
内存: Four 288-pin 1866/2133 MHz dual-channel unbuffered DDR4 DIMMs support up to 64GB |
扩展接口: 1 x Full-size PCIe Mini card slot (support mSATA)内置 1 x PCIe x16 slot 6 x PCI slot |
数字IO: 8-bit digital I/O (2x5 pin)内置 |
以太网: LAN1: Intel® I219LM PCIe controller LAN2: Intel® I211 PCIe controller外置 |
操作系统: win10 |
电源供电: 内置ATX电源供电 |
环境温度: -20°C ~ 60°C 相对湿度: 5%~ 95%,非冷凝 |
工作温度:-20°C ~ 60°C 相对湿度:5%~ 95% |
尺寸:320(W)X195(H)X331.5(D)mm |
重量:8.1Kg |
