产品指标
CPU: LGA 1151 socket supports Intel® 8th/9th Generation Core™ i9/i7/i5/i3, Celeron® and Pentium® processor |
内存: Four 288-pin 2666/2400 MHz Dual-Channel DDR4 SDRAM Unbuffered DIMMs supported up to 64GB |
硬盘: 2.5寸480G SSD SATA硬盘 |
显示接口: 1 x VGA (up to 1920 x 1080@60Hz)外置;
1 x DP++ (up to 4096 x 2304@60Hz)外置;
1 x HDMI (up to 4096 x 2304@30Hz)外置;
1 x Displayport (up to 4096 x 2304@60Hz) 内置
I/O接口: 1 x KB/MS (1x6 pin) 外置;1 x RS-232(DB9) 外置;
4 x USB 2.0 外置;4 x USB 3.1 外置;
6 x SATA 6Gb/s (RAID 0/1/5/10 supported) 内置;
2 x RS-232/422/485 (2x5pin, P=2.54) 内置;
3 x RS-232 (2x5 pin, P=2.54)内置
音频:3 x Audio jacks (line-out, line-in, mic-in) |
扩展接口: 2 x PCIe x8; 3 x PCIe x4;2x PCI slot ;
1 x M.2 A key (2230, PCIe x1 & USB 2.0)内置;
1 x M.2 M Key (2280, PCIe x2 only)内置 |
数字IO: 8-bit digital I/O (2x5 pin)内置
以太网: LAN1 : Intel® I219LM PCIe controller with AMT 11.0 support外置;
LAN2: Intel® I211AT PCIe controller外置 |
电源供电:内置ATX电源供电
操作系统:win10 |
工作环境:-20°C ~ 60°C
相对湿度:5%至95%,非冷凝 |
环境温度:-40℃~+80℃
相对湿度:5%至95%,非冷凝 |
尺寸:320(W)X195(H)X331.5(D)mm
重量:8.1Kg
