大电流电感CSCF2014B- 100MC产品规格书下载
消耗积分:0 | 格式:pdf | 大小:1.23 MB | 2022-03-25
CODACA科达嘉电感
分享资料个
Notice of Use 使用注意事项
10.1 Product in packing storage condition : temperature 5~40℃, RH≤ 70%. 产品在包装中的保存条件:温度 5~40℃,相对湿度小于等于 70%。 If taking out for use, the remaining products should be sealed in plastic bags and preserved in accordance with the above conditions, to avoid oxidation of terminals (electrodes), affecting soldering status. 如果取出使用,剩余的产品请用胶袋密封按照以上条件保存,避免端子(电极)氧化,影响焊接状态。
10.2 A storage of Codaca Electronic products for longer than 12 months is not recommended, Within other effects, the terminals may suffer degradation, resulting in bad solderability. Therefore, all products shall be used within the period of 12 months based on the day of shipment. 科达嘉电子产品储存期不建议超过12 个月,在其他影响下,端子可能会退化,导致焊接性差。 因此,所有产品应使用在 12 个月内以出货日为基础。
10.3 Do not keep products in unsuitable storage conditions, such as areas susceptible to high temperatures, high humidity, dust or corrosion. 请不要将产品保存于高温、高湿、有尘埃、腐蚀性气体的不适合环境中。
10.4 Always handle products with care. 请小心轻放,避免由于产品的跌落或取用不当而引致的损坏。
10.5 Don't touch electrodes directly with bare hands as oil secretions may inhibit soldering. Always ensure optimum conditions for soldering. 手上的油脂会导致可焊性降低,应避免用手直接接触端子
评论(0)
发评论
下载排行榜
