Ruby-God Ruby进程管理框架
消耗积分:0 | 格式:zip | 大小:0.20 MB | 2022-04-26
李梅
分享资料个
授权协议 MIT
开发语言 Ruby
操作系统 Linux
软件类型 开源软件
所属分类 管理和监控系统监控
软件简介
God 是一个使用 Ruby 写成的用于监视任务运行状态的可扩展框架,它的配置脚本同样采用 Ruby 来编写。因此,比起它的前辈 Monit,God 更为简单,灵活且易于扩展(尤其对于 Ruby 使用者),你可以很轻易的添加一些自定义规则。
示例:
# Events
I [2011-12-10 15:24:34]  INFO: Loading simple.god
I [2011-12-10 15:24:34]  INFO: Syslog enabled.
I [2011-12-10 15:24:34]  INFO: Using pid file directory: /Users/tom/.god/pids
I [2011-12-10 15:24:34]  INFO: Started on drbunix:///tmp/god.17165.sock
I [2011-12-10 15:24:34]  INFO: simple move 'unmonitored' to 'init'
I [2011-12-10 15:24:34]  INFO: simple moved 'unmonitored' to 'init'
I [2011-12-10 15:24:34]  INFO: simple [trigger] process is not running (ProcessRunning)
I [2011-12-10 15:24:34]  INFO: simple move 'init' to 'start'
I [2011-12-10 15:24:34]  INFO: simple start: ruby /Users/tom/dev/mojombo/god/simple.rb
I [2011-12-10 15:24:34]  INFO: simple moved 'init' to 'start'
I [2011-12-10 15:24:34]  INFO: simple [trigger] process is running (ProcessRunning)
I [2011-12-10 15:24:34]  INFO: simple move 'start' to 'up'
I [2011-12-10 15:24:34]  INFO: simple registered 'proc_exit' event for pid 23298
I [2011-12-10 15:24:34]  INFO: simple moved 'start' to 'up'
# Polls
I [2011-12-07 09:40:18]  INFO: Loading simple.god
I [2011-12-07 09:40:18]  INFO: Syslog enabled.
I [2011-12-07 09:40:18]  INFO: Using pid file directory: /Users/tom/.god/pids
I [2011-12-07 09:40:18]  INFO: Started on drbunix:///tmp/god.17165.sock
I [2011-12-07 09:40:18]  INFO: simple move 'unmonitored' to 'up'
I [2011-12-07 09:40:18]  INFO: simple moved 'unmonitored' to 'up'
I [2011-12-07 09:40:18]  INFO: simple [trigger] process is not running (ProcessRunning)
I [2011-12-07 09:40:18]  INFO: simple move 'up' to 'start'
I [2011-12-07 09:40:18]  INFO: simple start: ruby /Users/tom/dev/mojombo/god/simple.rb
I [2011-12-07 09:40:19]  INFO: simple moved 'up' to 'up'
I [2011-12-07 09:40:19]  INFO: simple [ok] process is running (ProcessRunning)
I [2011-12-07 09:40:24]  INFO: simple [ok] process is running (ProcessRunning)
I [2011-12-07 09:40:29]  INFO: simple [ok] process is running (ProcessRunning)
评论(0)
发评论
下载排行榜
