rttys 是 rtty 的服务器程序。
从 Release 页面下载编译好的二进制文件或者自己编译
go get -u github.com/zhaojh329/rttys
更新 statik
go get github.com/rakyll/statik statik -src=frontend/dist
命令行参数
./rttys -h
Usage of rttys:
-addr-dev string
address to listen device (default ":5912")
-addr-user string
address to listen user (default ":5913")
-conf string
config file to load (default "./rttys.conf")
-gen-token
generate token
-http-password string
password for http auth
-http-username string
username for http auth
-log string
log file path (default "/var/log/rttys.log")
-ssl-cert string
certFile Path
-ssl-key string
keyFile Path
-token string
token to use
-white-list string
white list(device IDs separated by spaces or *)
