yii2-rest-rbac Yii2权限管理RBAC rest接口
消耗积分:0 | 格式:zip | 大小:0.05 MB | 2022-06-30
李明聪
分享资料个
授权协议 MIT
开发语言 PHP
操作系统 跨平台
软件类型 开源软件
软件简介
yii2-rest-rbac是权限系统Yii2的rest版
  • 安装:
composer require windhoney/yii2-rest-rbac
使用
配置oauth2和rbac
   'modules' => [
        'rbac' => [
            'class' => 'wind\rest\modules'
        'oauth2' => [
            'class' => 'filsh\yii2\oauth2server\Module',
            'tokenParamName' => 'access_token',
            'tokenAccessLifetime' => 3600 * 24,
            'storageMap' => [
                'user_credentials' => 'backend\models\User',
            'grantTypes' => [
                'user_credentials' => [
                    'class' => 'OAuth2\GrantType\UserCredentials',
                'client_credentials' => [
                    'class' => 'OAuth2\GrantType\ClientCredentials',
                'refresh_token' => [
                    'class' => 'OAuth2\GrantType\RefreshToken',
                    'always_issue_new_refresh_token' => true
                'authorization_code' => [
                    'class' => 'OAuth2\GrantType\AuthorizationCode'
             'components' => [
                'request' => function () {
                    return \filsh\yii2\oauth2server\Request::createFromGlobals();
                'response' => [
                    'class' => \filsh\yii2\oauth2server\Response::class,
    'components' => [
        'authManager' => [
            'class' => 'wind\rest\components\DbManager', //配置文件
配置权限
    'as access' => [
        'class' => 'wind\rest\components\AccessControl',
        'allowActions' => [
            'site/*',//允许访问的节点,可自行添加
            'rbac/menu/user-menu',
            'oauth2/*',
创建所需要的表
1. 用户表user和菜单表menu
yii migrate --migrationPath=@vendor/windhoney/yii2-rest-rbac/migrations
2. rbac相关权限表
yii migrate --migrationPath=@yii/rbac/migrations/
auth_item 表添加一个字段 parent_name varchar(30) COLLATE utf8_unicode_ci DEFAULT '' COMMENT '父级名称',
3. oauth2相关表
yii migrate --migrationPath=@vendor/filsh/yii2-oauth2-server/migrations
4. 新增分组表
CREATE TABLE `auth_groups` (
  `group_id` varchar(50) NOT NULL COMMENT '分组id',
  `group_name` varchar(100) NOT NULL DEFAULT '' COMMENT '分组名称',
  `group_status` varchar(50) NOT NULL DEFAULT '' COMMENT '状态(开启,关闭)',
  PRIMARY KEY (`group_id`)
) ENGINE=InnoDB DEFAULT CHARSET=utf8 ;
CREATE TABLE `auth_groups_child` (
  `id` int(11) NOT NULL AUTO_INCREMENT,
  `user_id` varchar(64) NOT NULL COMMENT '用户id',
  PRIMARY KEY (`id`),
  UNIQUE KEY `group_id_2` (`group_id`,`user_id`),
  KEY `group_id` (`group_id`),
  KEY `user_group_id` (`user_id`) USING BTREE
) ENGINE=InnoDB AUTO_INCREMENT=795 DEFAULT CHARSET=utf8 ;
添加路由配置
  • 将yii2-rest-rbac/example/rbac_route.php文件内容配置到项目的urlManager的rules规则下
  • 或者在main.php文件中 添加
$dir = __DIR__ . "/route";
$main = wind\rest\helper\RbacHelper::addRoute($dir, $main);
return $main;
并将此文件放到config/route/rbac_route.php
接口文档参考
评论(0)
发评论
下载排行榜
