数字水位传感器无线变送器的设计方案
消耗积分:0 | 格式:rar | 大小:673 KB | 2011-03-18
刘明
分享资料个
  感应式数字水位传感器在传统的应用中,采集数据的传输都是采用有线传输。由于传统有线网络本身的局限性,许多特殊的环境下网络覆盖和网络支持仍然是个难题。针对这个问题,提出了基于ZigBee无线通信技术的便携式数字水位传感器无线变送器的设计方案。该变送器体积小,成本低,可操作性强,现场安装简单。由于采用ZigBee技术,更加适合组建有大量的现场数据采集点的监控系统,且组网灵活,极大地扩展了感应式数字水位传感器的应用范围。
  Abstract:
  In traditional applications of inductive digital water-level sensor, data acquired was transmitted by wire transmission. Owing to the limitations of traditional cable-Network itself, the coverage and technical support of cable-network is still a problem in many special circumstances. To address this issue, the design of wireless transmitter of portable digital water-level sensor based on ZigBee wireless communication technology is proposed in this paper. There are many advantages of this transmitter, such as small size, lower cost, easy operation, simple on-site installation, and so on. As a result of adopting the ZigBee technology, it is more suitable to construct a monitoring system of a large amount of on-site data collection point and flexible to construct network, and greatly extends the applications area of the digital water-level sensor.
评论(0)
发评论
下载排行榜
