AD8290 pdf datasheet (CMOS Sen
消耗积分:5 | 格式:rar | 大小:333 | 2009-03-24
分享资料个
The AD8290 contains both an adjustable current source to drive a sensor and a difference amplifier to amplify the signal voltage. The amplifier is set for a fixed gain of 50. The AD8290 is an excellent solution for both the drive and the sensing aspects required for pressure, temperature, and strain gage bridges.
In addition, because the AD8290 operates with low power, works with a range of low supply voltages, and is available in a low profile package, it is suitable for drive/sense circuits in portable electronics as well.
The AD8290 is available in a lead free 3.0 mm × 3.0 mm × 0.55 mm package and is operational over the industrial temperature range of −40°C to +85°C.
Applications
  • Bridge and sensor drives
  • Portable electronics
  • 声明:本文内容及配图由入驻作者撰写或者入驻合作网站授权转载。文章观点仅代表作者本人,不代表电子发烧友网立场。文章及其配图仅供工程师学习之用,如有内容侵权或者其他违规问题,请联系本站处理。 举报投诉
    评论(1)
    发评论
    PCB00035009 2021-01-21
    0 回复 举报
    谢谢分享,好资料 收起回复
    下载排行榜
    全部1条评论
