通过动态水循环智能灌溉您的院子。如果下雨或自上次浇水后一直下雨,请停止给院子浇水。使用光传感器检测日出时间并相应地自动调整水开始时间。如果太冷,请停止给院子浇水。
功能列表
按下菜单按钮显示菜单并继续按下按钮循环浏览所有菜单选项。不活动 30 秒后菜单将自动删除。按选择按钮执行所需的菜单功能。
将 Arduino Nano 连接到IO 扩展器并使用以下代码对其进行编程。6 针接头是软件串行调试端口,最终安装时不需要。
确保更改 ONEWIRE_TO_I2C_ROM1 和 ONEWIRE-TO_I2C_ROM2 定义的地址以匹配您的1-Wire 到 I2C地址。
/* IO Expander sketch optimized
* Irrigation System v1.1
#include
#include <time.h> // File located \Program Files (x86)\Arduino\hardware\tools\avr\avr\include\time.h
#include
#include
#include
#include "IOExpander.h"
#define FAHRENHEIT
#define INIT_BOARD "g5w1;g11w1;g11d0,75;g12w1;g12d0,75;rsf"
#define ONEWIRE_TO_I2C_ROM1 "i4scc"
#define ONEWIRE_TO_I2C_ROM2 "i6s8f"
#define ONEWIRE_TEMPERATURE "t6s0300"
#define RTC_SENSOR "s4te"
#define I2C_EEPROM "s4tf"
#define I2C_OLED "s4t10"
#define I2C_LIGHT "s3t9;sc0"
#define OPTICAL_SENSOR "g5a"
#define BUTTON1 "g11d"
#define BUTTON2 "g12d"
#define WATER_TIME_BEFORE_SUNRISE 60
#define SUNRISE_LUX 100
#define RAIN_DETECT_LEVEL 4.0
#define DO_NOT_WATER_TEMP 4.4444 // 40F
#define MAX_ZONES 4
#define HOUR_IN_DAY 24L
#define MIN_IN_HOUR 60L
#define SEC_IN_MIN 60L
#define SEC_IN_HOUR (MIN_IN_HOUR * SEC_IN_MIN)
#define SEC_IN_DAY (HOUR_IN_DAY * SEC_IN_HOUR)
#define DAYS_IN_WEEK 7
#define SEC_IN_WEEK (SEC_IN_DAY * DAYS_IN_WEEK)
#define SUN 0x01
#define MON 0x02
#define TUE 0x04
#define WED 0x08
#define THR 0x10
#define FRI 0x20
#define SAT 0x40
#define EVERYDAY (SUN | MON | TUE | WED | THR | FRI | SAT)
#define SUNRISE 0x80
#define MENU_OPTIONS 9
#define MENU_TIME 30
#define OFF 0
#define ON 1
#define STATE_ON_OFF 0x01
//#define SERIAL_DEBUG
#ifdef SERIAL_DEBUG
SoftwareSerial swSerial(8,7);
#endif
char weekday[][4] = {"SUN","MON","TUE","WED","THU","FRI","SAT"};
char menu[][13] = {"Next",
"Water",
"Reset",
"Clock Min +",
"Clock Min -",
"Clock Hour +",
"Clock Hour -",
"Sunrise",
"ON/OFF"};
enum {
MENU_NEXT,
MENU_WATER,
MENU_RESET,
MENU_CLOCK_MIN_PLUS,
MENU_CLOCK_MIN_MINUS,
MENU_CLOCK_HOUR_PLUS,
MENU_CLOCK_HOUR_MINUS,
MENU_SUNRISE,
MENU_ON_OFF
typedef struct {
char description[16];
uint8_t relay;
} ZONE;
typedef struct {
uint8_t zone;
uint8_t days;
int8_t hour;
int8_t min;
uint8_t duration;
} SCHEDULE;
typedef struct {
time_t sunrise_time;
time_t last_water_time;
uint8_t water_schedule;
uint8_t water_duration;
uint8_t rain[MAX_ZONES];
uint8_t state;
uint8_t crc;
} NVRAM;
enum {
ZONE1,
ZONE2,
ZONE3,
ZONE4
enum {
RELAY1 = 1,
RELAY2,
RELAY3,
RELAY4
ZONE zone[] = {
{"Front Right", RELAY1},
{"Front Left", RELAY2},
{"Bushes", RELAY3},
{"Left Side", RELAY4},
SCHEDULE schedule[] = {
{ZONE1, SUNRISE | EVERYDAY, -1, 0, 4},
{ZONE2, EVERYDAY, 6, 15, 5},
{ZONE3, EVERYDAY, 6, 0, 10},
{ZONE4, EVERYDAY, 6, 10, 6},
NVRAM nvram;
bool update_nvram = false;
uint8_t crc8(uint8_t* data, uint16_t length)
uint8_t crc = 0;
while (length--) {
crc = _crc8_ccitt_update(crc, *data++);
return crc;
int led = 13;
bool init_oled = true;
bool update_oled = true;
bool init_board = true;
#ifdef FAHRENHEIT
#define C2F(temp) CelsiusToFahrenheit(temp)
float CelsiusToFahrenheit(float celsius)
return ((celsius * 9) / 5) + 32;
#else
#define C2F(temp) (temp)
#endif
void SerialPrint(const char* str, float decimal, char error)
Serial.print(str);
if (error) Serial.print(F("NA"));
else Serial.print(decimal, 1);
time_t NextScheduleTime(time_t last_time, uint8_t* next_schedule)
time_t next_time = -1;
time_t clk_time;
uint8_t i;
tm clk;
uint8_t wday;
for (i = 0; i < sizeof(schedule) / sizeof(SCHEDULE); i++) {
if (schedule[i].days & SUNRISE) {
clk_time = nvram.sunrise_time;
clk_time += schedule[i].hour * SEC_IN_HOUR;
clk_time += schedule[i].min * SEC_IN_MIN;
localtime_r(&clk_time, &clk);
else {
localtime_r(&last_time, &clk);
clk.tm_hour = schedule[i].hour;
clk.tm_min = schedule[i].min;
clk.tm_sec = 0;
clk_time = mktime(&clk);
wday = clk.tm_wday;
while (clk_time <= last_time || !(schedule[i].days & (1 << wday)))
clk_time += SEC_IN_DAY;
if (++wday > SATURDAY) wday = SUNDAY;
if (wday == clk.tm_wday) break; // Only check one week
if (clk_time < next_time) {
next_time = clk_time;
*next_schedule = i;
return next_time;
void StartScheduleTime(time_t start_time, uint8_t start_schedule)
uint8_t i;
nvram.last_water_time = start_time;
nvram.water_schedule = start_schedule;
nvram.water_duration = schedule[start_schedule].duration+1;
update_nvram = true;
// Check if it rained
i = schedule[start_schedule].zone;
if (i < MAX_ZONES && nvram.rain[i] > 0) {
if (nvram.rain[i] > nvram.water_duration) nvram.water_duration = 0;
else nvram.water_duration -= nvram.rain[i];
nvram.rain[i] = 0;
void WaterScheduleTime(void)
uint8_t i;
nvram.water_duration--;
i = schedule[nvram.water_schedule].zone;
if (i < MAX_ZONES) {
Serial.print("r");
Serial.print(zone[i].relay);
if (nvram.water_duration > 0) Serial.println("o");
else Serial.println("f");
SerialReadUntilDone();
void setup() {
Serial.begin(115200);
#ifdef SERIAL_DEBUG
swSerial.begin(115200);
#endif
pinMode(led, OUTPUT);
//delay(1000);
wdt_enable(WDTO_8S);
void loop() {
static tm rtc;
tm clk, sunrise_clk;
time_t rtc_time;
time_t clk_time;
static time_t next_time;
static uint8_t last_sec;
static uint8_t last_min;
bool error_rtc;
bool error_light;
bool error_temp;
static long lux = 0;
static float temp, rain;
static uint8_t sunrise_counter = MIN_IN_HOUR;
static bool check_sunrise = false;
uint8_t i;
static bool read_nvram = true;
static time_t water_time;
static uint8_t water_schedule;
uint8_t sz;
uint8_t wday;
long n;
bool button1, button2;
static int8_t menu_select = -1;
static time_t menu_time = 0;
Serial.println();
if (SerialReadUntilDone()) {
if (init_board) {
SerialCmdDone(INIT_BOARD);
init_board = false;
if (init_oled) {
if (SerialCmdNoError(ONEWIRE_TO_I2C_ROM1)) {
SerialCmdDone(I2C_OLED ";si;sc;sd");
init_oled = false;
if (SerialCmdDone(RTC_SENSOR)) {
error_rtc = !SerialReadTime(&rtc);
if (!error_rtc) {
clk = rtc; // mktime() can change struct tm
rtc_time = mktime(&clk);
localtime_r(&rtc_time, &rtc); // Get wday.
if (read_nvram) {
if (SerialCmdNoError(I2C_EEPROM)) {
SerialReadEEPROM((uint8_t*)&nvram, 0, sizeof(nvram));
if (nvram.crc != crc8((uint8_t*)&nvram, sizeof(nvram)-sizeof(uint8_t))) {
//swSerial.println("CRC8 Failure!");
// Initialize nvram
memset(&nvram, 0, sizeof(nvram));
clk = rtc;
clk.tm_hour = 6;
clk.tm_min = 0;
clk.tm_sec = 0;
nvram.sunrise_time = mktime(&clk);
if (nvram.sunrise_time < rtc_time) nvram.sunrise_time + SEC_IN_DAY;
// Check last water time no less than one week
if (rtc_time - nvram.last_water_time > SEC_IN_WEEK) nvram.last_water_time = rtc_time - SEC_IN_WEEK;
// Check sunrise time
if (rtc_time > nvram.sunrise_time) {
localtime_r(&nvram.sunrise_time, &sunrise_clk);
clk = rtc;
clk.tm_hour = sunrise_clk.tm_hour;
clk.tm_min = sunrise_clk.tm_min;
clk.tm_sec = sunrise_clk.tm_sec;
if (nvram.water_duration) {
nvram.water_duration++;
water_time = nvram.last_water_time;
else {
clk_time = (nvram.last_water_time) ? nvram.last_water_time : rtc_time;
water_time = NextScheduleTime(clk_time, &water_schedule);
read_nvram = false;
// Process only once every minute
if (rtc.tm_min != last_min)
// Request a 1-Wire temperature measurement. Read it later.
error_temp = !SerialCmdNoError(ONEWIRE_TEMPERATURE);
if (!error_temp) SerialCmdDone("tt");
error_light = !SerialCmdNoError(ONEWIRE_TO_I2C_ROM2 ";oo0");
if (!error_light) {
SerialCmdDone(I2C_LIGHT); // Do not use overdrive
SerialCmd("sr");
SerialReadInt(&lux);
if (SerialCmd(OPTICAL_SENSOR)) {
SerialReadFloat(&rain);
if (!error_temp) {
SerialCmd("tr");
SerialReadFloat(&temp);
// Is it sunrise?
if (lux < SUNRISE_LUX) {
if (sunrise_counter > 0) sunrise_counter--;
else check_sunrise = true;
else {
if (sunrise_counter < MIN_IN_HOUR) {
sunrise_counter++;
if (check_sunrise && sunrise_counter == MIN_IN_HOUR) {
nvram.sunrise_time = rtc_time + (SEC_IN_DAY - SEC_IN_HOUR);
// Is it raining?
if (rain <= RAIN_DETECT_LEVEL) {
for (i = 0; i < MAX_ZONES; i++) {
if (nvram.rain[i] < -1) nvram.rain[i]++;
// Check schedule
if (menu_select == -1 && !nvram.water_duration) {
while (water_time + (schedule[water_schedule].duration * SEC_IN_MIN) < rtc_time) {
water_time = NextScheduleTime(water_time, &water_schedule);
if (water_time <= rtc_time) {
StartScheduleTime(water_time, water_schedule);
if (temp <= DO_NOT_WATER_TEMP || nvram.state & STATE_ON_OFF == OFF)
// Do we need to water?
WaterScheduleTime();
if (!nvram.water_duration)
last_min = rtc.tm_min;
update_oled = true;
// Check buttons
button1 = SerialReadButton(BUTTON1);
if (button1) {
if (menu_select == -1) menu_select = 0;
else {
if (++menu_select >= MENU_OPTIONS)
menu_select = 0;
menu_time = rtc_time;
update_oled = true;
if (menu_select >= 0) {
button2 = SerialReadButton(BUTTON2);
if (button2) {
clk_time = rtc_time;
switch(menu_select) {
case MENU_NEXT:
case MENU_RESET:
nvram.water_duration = 1;
water_time = NextScheduleTime((menu_select == MENU_NEXT) ? water_time : rtc_time, &water_schedule);
break;
case MENU_WATER:
break;
case MENU_CLOCK_MIN_PLUS:
clk_time += SEC_IN_MIN;
break;
case MENU_CLOCK_MIN_MINUS:
clk_time -= SEC_IN_MIN;
break;
case MENU_CLOCK_HOUR_PLUS:
clk_time += SEC_IN_HOUR;
break;
case MENU_CLOCK_HOUR_MINUS:
clk_time -= SEC_IN_HOUR;
break;
case MENU_ON_OFF:
nvram.state ^= STATE_ON_OFF;
break;
if (clk_time != rtc_time) {
SerialWriteTime(&clk);
rtc_time = clk_time;
update_oled = true;
if (menu_select >= 0 && rtc_time - menu_time > MENU_TIME) {
menu_select = -1;
update_oled = true;
if (update_oled) {
Serial.print("st10;so1;sc;sf0;sa0;sd0,0,\"");
if (nvram.water_duration) Serial.print(nvram.water_duration);
else {
if ((nvram.state & STATE_ON_OFF) == OFF) Serial.print("OFF");
else if (rain <= RAIN_DETECT_LEVEL) Serial.print("Rain");
else if (temp <= DO_NOT_WATER_TEMP) Serial.print("Cold");
else Serial.print("v1.1");
Serial.print("\";sf2;sa1;sd75,0,\"");
if (menu_select == 7) { // Sunrise
else clk = rtc;
Serial.print(clk.tm_hour-((clk.tm_hour>12)?12:0));
Serial.print(":");
if (clk.tm_min < 10) Serial.print("0");
Serial.print(clk.tm_min);
Serial.println("\"");
Serial.print("sf1;sa0;sd79,8,\"");
Serial.print((clk.tm_hour>12)?"PM":"AM");
Serial.print("\";sf0;sa1;sd127,1,\"");
Serial.print(weekday[clk.tm_wday]);
Serial.print("\";sd127,13,\"");
Serial.print(clk.tm_mon+1);
Serial.print("/");
Serial.print(clk.tm_mday);
Serial.print("sf0;sa0;sd1,36,\"");
i = schedule[water_schedule].zone;
if (i < MAX_ZONES) Serial.print(zone[i].description);
localtime_r(&water_time, &clk);
if (water_time - rtc_time > SEC_IN_DAY) {
Serial.print("\";sa1;sd126,36,\"");
Serial.print("/");
Serial.print(" ");
Serial.print(":");
Serial.print(" ");
else {
Serial.print("\";sf1;sa1;sd111,30,\"");
Serial.print(":");
Serial.print("\";sf0;sd126,36,\"");
if (nvram.water_duration) Serial.print("\";so2;sc0,29,128,19");
Serial.println();
if (menu_select == -1) {
//Serial.print("\";sa0;sd0,52,\"");
//Serial.print(rain);
SerialPrint("\";so1;sa2;sd63,52,\"", C2F(temp), error_temp);
if (!error_temp) Serial.print("\",248,\""
#ifdef FAHRENHEIT
"F"
#else
"C"
#endif
Serial.print(" / ");
Serial.print(lux);
else {
Serial.print("\";so0;sc0,51,128,14;sf0;sa2;sd63,52,\"");
if (menu_select == MENU_ON_OFF) {
Serial.print((nvram.state & STATE_ON_OFF) ? "OFF" : "ON");
else Serial.print(menu[menu_select]);
Serial.println("\";sd");
update_oled = false;
else init_oled = true;
if (update_nvram) {
nvram.crc = crc8((uint8_t*)&nvram, sizeof(nvram)-sizeof(uint8_t));
//swSerial.println(nvram.crc, HEX);
SerialWriteEEPROM((uint8_t*)&nvram, 0, sizeof(nvram));
delay(50);
else {
digitalWrite(led, HIGH);
delay(500);
digitalWrite(led, LOW);
delay(500);
init_board = true;
init_oled = true;
wdt_reset();
注意:如果您使用 USB 端口对 Arduino Nano 进行编程,则必须将其与IO 扩展器断开,因为它也使用相同的单个串行端口,而不是如果您想调试使用 ICSP 端口对 ATmega328P 进行编程。要启用软件调试端口,请取消注释 SERIAL_DEBUG 定义。
必须首先配置分路器以将光学红外传感器数据线与 1-Wire 远程传感器线隔离。在 R2 处焊接一个零欧姆 0603 电阻。
在 PG7 和 PG11 右侧的小外壳上钻一个 7/16" 的孔,在较大的外壳上钻一个 11/16" 的孔。使用 dremel 工具稍微扩大孔,直到压盖贴合。PG7 将为远程传感器和 PG11 供电,用于 12VDC、24VAC、歧管线和 RJ11 远程传感器线。
连接 SPST 瞬时按钮微动开关并将其连接到 RJ11 螺钉端子。使用热缩管对触点进行绝缘。
连接所有电线并将所有零件组装/送入大型外壳。用于远程传感器的 50 英尺 RJ11 线应刚好穿过 PG11 密封套,而无需切断它。
在光学红外水传感器的小外壳顶部钻一个 9/16" 孔。使用 dremel 工具稍微扩大孔直到传感器适合。小型远程传感器外壳是紧密配合的,但如果内容以建议的方向铺设,它应该正好适合。使 RJ11 线尽可能短将有助于将其全部塞入较小的外壳中。组装后,建议在拧紧螺母之前在压盖螺母垫圈中添加一些船用胶水,创造更好的印章。
将远程传感器外壳安装在室外,并将其安装在房屋的东侧,使光学红外水传感器和光传感器指向天空,无障碍物。
在大外壳的顶部中间底部钻 1/4" 孔并安装按钮。使用 dremel 工具稍微扩大孔,直到按钮适合。
测试系统并确保一切正常。要测试继电器和传感器,请断开 Arduino 与IO 扩展器的连接,并将其直接连接到您的计算机以手动控制它。确认一切正常后,使用双面胶带和包装泡沫将所有部件组装到外壳中以固定您的电路板,并享受智能灌溉控制器的好处和节省。
发布的 v1.1 修复了系统断电数天时出现的启动问题。
将 1-Wire 连接到 I2C 到 DS3231,然后连接到 SSD1306 OLED 屏幕时,您将在 SDA 和 SCL 线上总共有三个不同的上拉电阻,如下图圆圈所示。这将有效地导致 4.7k / 3 = 1.56k 的上拉,可能太强并导致随机屏幕损坏。
由于 DS3231 使用其他线路使用的电阻器组,请移除其他上拉电阻器:
