加尔各答的服装和塑料行业的业主通常会在他们的行业中经常遇到火灾,因此为了防止这种情况并采取快速行动,这个火灾探测系统可能很有用。
项目的功能
出于安全原因,我将温度限制保持在摄氏二十八度。
maximum_limit = 28.0
temp = (100*sensor_value)/1024
电路原理图 :
LM35- Temperature Sensor
Buzzer
LED
SID = 'TWILIO SID'
AUTH_TOKEN = 'TWILIO AUTH TOKEN'
FROM_NUMBER = 'NUMBER GIVEN BY TWIILIO'
TO_NUMBER = 'YOUR NUMBER WHICH IS VERIFIED IN TWILIO'
MAILGUN_API_KEY = 'MAILGUN API KEY'
SANDBOX_URL= 'SANDBOX URL'
SENDER_EMAIL = 'test@' + SANDBOX_URL # No need to modify this. The sandbox URL is of the format test@YOUR_SANDBOX_URL
RECIPIENT_EMAIL = 'YOUR MAIL ID'
API_KEY = 'BOLT API KEY'
DEVICE_ID = 'BOLD DEVICE ID'
THANK YOU FOR THE PATIENCE , HAVE A GREAT DAY :)
