ALTERA编程电缆数据手册
消耗积分:0 | 格式:pdf | 大小:313 KB | 2011-07-11
分享资料个
You can use the ByteBlasterMV™ download cable to do the following:
■ Download configuration data to SRAM-based devices, such as Stratix® II,
Stratix GX, Stratix, CycloneTM II Cyclone, APEXTM II, APEX 20K
(including APEX 20K, APEX 20KE, and APEX 20KC), ACEX® 1K,
MercuryTM , FLEX® 10K (including FLEX 10KA and FLEX 10KE),
FLEX 8000, FLEX 6000, and ExcaliburTM devices.
■ Download configuration data to EEPROM-based devices, such as MAX® II,
MAX 9000, MAX 7000S, MAX 7000AE, MAX 7000B, and MAX 3000A
■ Perform in-system programming of advanced configuration (EPC2, EPC4,
EPC8, and EPC16)
■ Perform SignalTap II logic analysis
■ Connect the ByteBlasterMV download cable directly to your PC’s parallel
port, a Linux workstation parallel port, or through an Altera Software Guard
that is connected to the parallel port.
评论(0)
发评论
下载排行榜
