0.1W蓝光LED数据手册
消耗积分:0 | 格式:pdf | 大小:349 KB | 2011-07-16
分享资料个
本内容提供了0.1W蓝光LED数据手册
Description
The Blue source color devices are made with Gallium
Arsenide Phosphide on Gallium Phosphide Blue Light
Emitting Diode.
Notes:
1. All dimension units are millimeters.
2.All dimension tolerance is ±0.2mm unless otherwise noted.
3.An epoxy meniscus may extend about 1.5mm down the leads.
评论(1)
发评论
lcm2179 2015-11-24
0 回复 举报
谢谢分享 收起回复
下载排行榜
全部1条评论
