It is well known that the unit of digital data rate is bps (bits per second), Mbps (Megabits per second), or Gbps (Giga bits per second) while the unit of frequency is Hz (Hertz), MHz (Mega Hertz) or GHz (Giga Hertz). They are comparable because they have the same dimension, 1/second. In respect to RF (radio frequency), a digital circuit can be distinguished into two cases: low and high digital data rate.
