在本教程中,您将创建一个带有按钮的简单项目,每次按下它都会向您的手机发送推送通知。
请注意如何将电池模块放在底部。它是唯一可以以错误方式插入的模块。
您需要将 Core 模块与您正在使用的 Radio dongle 配对,按照下面的说明查看它是如何完成的。
如果您没有看到流程,您可以复制下面的文本并将其粘贴到 Node-RED 的菜单 > 导入 > 剪贴板
[{"id":"103c675c.c81139","type":"mqtt in","z":"2c41a2bd.aa36ae","name":"","topic":"node/push-button:0/push-button/-/event-count","qos":"2","broker":"29fba84a.b2af58","x":270,"y":360,"wires":[["ff41c7e0.06eba8"]]},{"id":"f507ecc3.8f82b","type":"blynk-ws-out-notify","z":"2c41a2bd.aa36ae","name":"Blynk notification","client":"fc4bbabb.9bb1b8","queue":false,"rate":5,"x":790,"y":360,"wires":[]},{"id":"ff41c7e0.06eba8","type":"change","z":"2c41a2bd.aa36ae","name":"Set message","rules":[{"t":"set","p":"payload","pt":"msg","to":"Button pressed, you're the best!","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":570,"y":360,"wires":[["f507ecc3.8f82b"]]},{"id":"c131dd35.bb855","type":"comment","z":"2c41a2bd.aa36ae","name":"Push Button Kit flow","info":"","x":190,"y":300,"wires":[]},{"id":"29fba84a.b2af58","type":"mqtt-broker","z":"","broker":"127.0.0.1","port":"1883","clientid":"","usetls":false,"compatmode":true,"keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","willTopic":"","willQos":"0","willPayload":""},{"id":"fc4bbabb.9bb1b8","type":"blynk-ws-client","z":"","name":"","path":"ws://blynk-cloud.com/websockets","key":"5cf554e34caf4d49a1b24cd07c5e2c13","dbg_all":false,"dbg_read":false,"dbg_write":false,"dbg_notify":false,"dbg_mail":false,"dbg_prop":false,"dbg_sync":false,"dbg_bridge":false,"dbg_low":false,"dbg_pins":"","multi_cmd":false,"proxy_type":"no","proxy_url":""}]
该项目应该与 Blynk 一起使用。HARDWARIO 教程中解释了如何设置blynk 。
如果您完成了整个教程,您的手机中应该有一个下载的 Blynk 应用程序。
点击右上角的二维码图标,扫描以下二维码。
您将需要一个 Auth Token 来设置 Blynk 和 Node-RED 连接,您可以通过应用程序将其通过电子邮件发送给您。
现在您只需按下按钮
推送后,您应该会在手机上收到通知
这只是您可以使用 HARDWARIO IoT Kit 完成的一个基本项目。当然,您可以将其扩展得更多,只需按下按钮即可制作出很棒的东西。
如果您想查看更多这样的入门项目,您可以访问此类别中的项目。
随时问,我会尽力回答任何问题。
