MAX9972 四通道300Mbps ATE驱动器_比较器
消耗积分:0 | 格式:pdf | 大小:333 KB | 2011-10-26
分享资料个
The MAX9972 four-channel, ultra-low-power, pin-electronicsIC includes, for each channel, a three-level pindriver, a window comparator, a passive load, andforce-and-sense Kelvin-switched parametric measurementunit (PMU) connections. The driver features a-2.2V to +5.2V voltage range, includes high-impedanceand active-termination (3rd-level drive) modes, and ishighly linear even at low voltage swings. The windowcomparator features 500MHz equivalent input bandwidthand programmable output voltage levels. Thepassive load provides pullup and pulldown voltages tothe device-under-test (DUT).
评论(0)
发评论
下载排行榜
