基于多重网格方法的快速电源网格分析法
消耗积分:3 | 格式:rar | 大小:227 | 2009-05-06
王银喜
分享资料个
以电源网络节点之间的电气距离为基础,应用多重网格方法,提出了一种快速的电源网格分析器;设计了一个简单的限制和插值方案,速度收敛可以通过电气距离阀值和前/后段滤波迭代次数来控制。基于电源网格节点间电气距离方案的特点在于直观、简单、易于实现,实验结果较好地证明了该方法的可行性。Power grid analysis is an important issue for circuit design and verification. With the increasing number of transistors on a chip, the size of the power networks has grown so large as to make the verification task very challenging. Fast and memory-saving power analysis algorithms are needed. In this paper, we present a fast power grid analyzer using multigrid technique, which speed up the convergence of sparse iterative solver. we proposed a simple and intuitive restriction and interpolation scheme, which is based on the electric distance between the nodes in the power grid network. The convergence can be controlled by a user specified threshold parameter and pre/post smoothing iterations. Experimental results show the efficiency of the new method.
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
