The MAX197 multi-range, 12-bit data-acquisition system(DAS) requires only a single +5V supply for operation,yet accepts signals at its analog inputs that may span both above the power-supply rail and below ground. This system provides 8 analog input channels that are independently software programmable for a variety of ranges: ±10V, ±5V, 0V to +10V, or 0V to +5V.
