多信息融合技术及在无损检测中的应用
消耗积分:3 | 格式:rar | 大小:195 | 2009-05-14
385288
分享资料个
研究了基于D-S证据理论的多传感器决策层信息融合的实现方法和算法,探讨了将Dempster联合规则推广到多源信息时取消中间联合过程的归一化计算问题,推导出了改进算式。应用于无损检测,用超声波等三种传感器对一铸件进行无损检测仿真实验,结果证明能够提高检测速度与检测精度。
In this paper, the method and algorithm of multi-sensor decision-making level based on D-S evidence theory are researched in the light of basic theory knowledge of the multi-sensor information fusion, and the detailed formulations are reasoned without middle normalizing unity calculation with extending Dempster rule to multi-source information, which can reduce the calculation quantity. When this method is used to the nondestructive testing experiment that three kinds of sensors detects a casting, the result has proved this improved algorithm can improve detection precision and speed.
评论(0)
发评论
下载排行榜
