XAPP944 - 将Xilinx CoolRunner-II CPLD用作数据流开关
消耗积分:0 | 格式:pdf | 大小:40 KB | 2012-02-09
分享资料个
This application note shows how a Xilinx CoolRunnerTM-II CPLD can be used as a simplelogical switch that can quickly and reliably select between different MPEG video sources. Thesource code for the design is available on the Xilinx website, and is linked from the “VHDLCode” section. The code can be expanded by the user to perform additional operations usingthe remaining CPLD resources
评论(0)
发评论
下载排行榜
