XAPP946-适用于Virtex-4 RocketIO MGT的开关电源
消耗积分:0 | 格式:pdf | 大小:457 KB | 2012-02-10
分享资料个
This document presents design techniques and reference circuits that power Virtex™-4 FXRocketIO™ multi-gigabit transceivers (MGTs) operating at data rates below 3.125 Gb/s.When using multiple transceivers, it is sometimes preferred to power them from a switchingpower supply. However, switching power supplies generate noise that affects transceiver
. This application note describes techniques that can be used to avoid powersupply-induced performance degradation on RocketIO links. It presents performance dataobtained with an ideal power supply, a low-noise switching regulator, and a noisy switchingregulator for 2.5 Gb/s and 3.125 Gb/s data rates.
评论(0)
发评论
下载排行榜
