CD4511BC.pdf
消耗积分:10 | 格式:rar | 大小:122 | 2008-04-02
安立路
分享资料个
The CD4511BC BCD-to-seven segment latch/decoder/
driver is constructed with complementary MOS (CMOS)
enhancement mode devices and NPN bipolar output drivers
in a single monolithic structure. The circuit provides the
functions of a 4-bit storage latch, an 8421 BCD-to-seven
segment decoder, and an output drive capability. Lamp test
(LT), blanking (BI), and latch enable (LE) inputs are used to
test the display, to turn-off or pulse modulate the brightness
of the display, and to store a BCD code, respectively. It can
be used with seven-segment light emitting diodes (LED),
incandescent, fluorescent, gas discharge, or liquid crystal
readouts either directly or indirectly.
Applications include instrument (e.g., counter, DVM, etc.)
display driver, computer/calculator display driver, cockpit
display driver, and various clock, watch, and timer uses.
Features
 Low logic circuit power dissipation
 High current sourcing outputs (up to 25 mA)
 Latch storage of code
 Blanking input
 Lamp test provision
 Readout blanking on all illegal input combinations
 Lamp intensity modulation capability
 Time share (multiplexing) facility
 Equivalent to Motorola MC14511
下载资料需要登录,并消耗一定积分。
评论(0)
发评论
下载排行榜
