Applications
CDMA/LTE handset, data card & mobile router applications using the extension PCS band (Band Class 14) / BC1 / B25
Product Features
Excellent Triple Beat Performance: −88 dBc
Highly Selective BAW Duplexer Achieving Low Insertion Loss Over Full Bandwidth & Operating Conditions.
Rx Isolation Of +50 dB Minimum & GPS Rejection Of 》40 dB Eliminating The Need For A Transmit Filter
Single-Ended (SE) 50 Ω Receive & Transmit Ports
Performance −10 °C to +85 °C
RoHS Compliant, Pb-Free Module Package
General Description
The TQM963014 is a high-performance Bulk Acoustic Wave (BAW) duplexer designed to meet the strict CDMA / LTE requirements for use in the PCS extension band, known as Band Class 14 (BC14), BC1, and B25.
TQM963014 is specifically designed to meet the high performance expectations of insertion loss, isolation and triple beat for CDMA systems over the extended bandwidth of BC14/BC1/B25 applications under all operating conditions. Due to the exceptional receive isolation & GPS rejection performance, no transmit SAW filter is required.
The TQM963014 uses common module packaging techniques to achieve the industry standard 2.5 x 2.0 x 0.9 mm footprint. The duplexer exhibits excellent power handling capabilities.
