补偿压力传感器MPX2000系列可以与数字系统的A D输入接
消耗积分:2 | 格式:rar | 大小:167 | 2009-05-22
胡秋阳
分享资料个
Compensated semiconductor pressure sensors such as
the MPX2000 family are relatively easy to interface with digital
systems. With these sensors and the circuitry described
herein, pressure is translated into a 0.5 to 4.5 volt output range
that is directly compatible with Microcomputer A/D inputs. The
0.5 to 4.5 volt range also facilitates interface with an LM3914,
making Bar Graph Pressure Gauges relatively simple.
评论(0)
发评论
下载排行榜
