Common practice bounds their use in conventional boost PFC stages, yet Transition Mode (TM) Power Factor Corrector IC’s can be used in applications different from those they are primarily intended for.This is particularly true for the L6561, PFC controller for medium-low power applications, because of its peculiar characteristics.Reference [2] presents a special example showing how to extend the use of this device to Mag Amp applications.
