Selecting the proper set of components for a Katmai power supply based on the RC5051 requires detailed understanding of both the specs and the IC. Using the calculations provided in this Application Bulletin enables you to select components that will minimize the total cost, while ensuring that the power still meets all of the specification requirements under worst case. Katmai reference designs for both 5V and 12V input are provided.
