PLC在挤出机温度控制中的应用
消耗积分:5 | 格式:rar | 大小:141 | 2009-06-01
时见栖鸦
分享资料个
针对温度控制在塑料挤出中的重要性,本文介绍了以可编程序控制器为核心、采用智
能PID 算法和脉宽调制原理的挤出机温度控制系统,并介绍了该系统的硬件组成及软件编 程的方法和技巧。该温控系统硬件简单、控温精度高、性能稳定,具有较高的实用价值。
 关键词: 可编程序控制器;温度控制;比例积分微分算法;脉宽调制
Application of PLC to Temperature Control System in Extruder YANG-Peng ZANG-Chunhua WEI-Lifeng (Information Engineering Institute, Shenyang Institute of Chemical Technology, Shenyang 110142, China) Abstract:A method of temperature control system adopting PID algorithm, PWM(pulse width modulation) theorem based on PLC is dealt with ,which is used in plastics extrusion machine .The hardware configuration and technology of software design are also given. The advantage of this method is its accuracy and reliability of temperature controlling.
Key words: PLC; temperature control; PID; pulse width modulation
评论(0)
发评论
下载排行榜
