三维物体表面轮廓测量中实用相位展开算法的研究A Practi
消耗积分:5 | 格式:rar | 大小:182 | 2009-06-04
分享资料个
在利用FTP进行三维物体表面轮廓测量时,影响测量精度的关键因素之一是相位
的展开算法。传统的相位展开算法受展开路径的影响。本文在传统相位展开算法的基础上,提出了一种实用的不完全依赖展开路径的相位展开算法,该算法使噪声对精度的影响可减到最小并且易于操作。
关键词: FTP、相位展开算法、展开路径
Abstract: FTP is used to measure the 3D object surface, and one of the key factors about
measurement precision is the unwrapping algorithm. The traditional phase-unwrapping algorithm is affected by the path of the Unwrapping. Based on the traditional algorithm, this paper research a practical algorithm, which has a less relation about the path, so the precision influenced by noise can reduce to the least and ease to manipulate.
Key words: FTP, phase-unwrapping algorithm , Unwrapping path
评论(0)
发评论
下载排行榜
