本文提出了基于.NET Remoting 技术的电能质量监测数据发布模型。采用该模型有利 于提高监测数据的传输效率,使电能质量网络化监测的系统扩展性、兼容性、可移植性更好。最后采用某系统的电能质量数据作为数据源进行测试,证明了该模型的可行性和实用性。 关键词:.NET Remoting;DataSocket;电能质量;监测 Abstract:In this paper, a model of power quality monitoring data deploy based on .NET Remoting technology is proposed, which validates the higher transmission efficiency of data and the monitoring system is more expansible, compatible and transplantable. Finally, test this solution with a simulated power quality data source and the test result shows the proposed model is feasible and effective. Keywords:.NET Remoting ;DataSocket;Power quality;Monitor
