The MAX2181 is a highly integrated FM variable-gainlow-noise amplifier ideal for use in automotive FM andFM-diversity active antenna applications. The devicefeatures an FM signal path, providing 30dB of gain range,controlled by an on-chip power detector. The FM signalpath covers 76MHz to 162.5MHz.
