连接CY7B923和CY7B933(HOTlink器件)至宽
消耗积分:5 | 格式:rar | 大小:124 | 2009-06-16
分享资料个
This application note considers general interfacing issues between
the Cypress CY7B923/CY7B933 (HOTLink™) Transmitter/
Receiver and Cypress clocked FIFOs. The focus is on
applications with a 36-bit data bus requiring high data transfer
rates. A parallel FIFO solution is recommended for applications
requiring large data bandwidth. Four FIFOs can achieve
parallel data transfers on and off a 36-bit bus at rates of up to
280 Mbytes/s. The HOTLink serial link can transfer data at a
serial rate of 330 Mbits/s. The FIFOs act as asynchronous
storage buffers between the data bus and the serial link.
评论(0)
发评论
下载排行榜
