TMU3100,pdf datasheet (USB Con
消耗积分:5 | 格式:rar | 大小:322 | 2009-06-22
五斤麻辣油
分享资料个
The TMU3100 is an 8-bit microprocessor embedded device tailored to the USB/PS2 Keyboard application. It includes an 8-bit RISC CPU core, 192-byte SRAM, Low Speed USB Interface and an 8K x 14 internal program OTP-ROM.
FEATURE
􀂄 Compliance with the Universal Serial Bus specification v1.1
􀂄 Built-in USB Transceiver and 3.3V regulator
􀂄 Support USB Suspend and Resume function
􀂄 One Control IN/OUT and two Interrupt IN endpoints
􀂄 PS2 compatible keyboard interface share with USB interface
􀂄 192 byte internal SRAM
􀂄 8K x 14 internal program OTP-ROM
􀂄 8-bit RISC CPU core with only 36 instruction
􀂄 3MHz instruction rate with 6MHz crystal oscillation
􀂄 40/48 pin package
评论(0)
发评论
下载排行榜
