油管壁厚测量数据的一致性加权融合估计算法
消耗积分:5 | 格式:rar | 大小:154 | 2009-06-26
golabs
分享资料个
在随机扰动环境中采用漏磁场法在线测量油管壁厚时,每个磁性传感器只能得到环境的
部分信息。为了对各传感器的局部测量值进行稳健融合估计,提出了油管壁厚测量数据的一致性加权融合估计算法。利用改进的数据探测技术中的分布图方法对各个传感器的一致性进行检验,并采用简单加权平均法求得一致性传感器测量数据的稳健融合估计值。融合实例表明,该算法能有效地提高系统测量的稳健性,且具有精度高、运算简单等特点。该算法适用于多传感器测量数据的实时高精度融合估计。
关键词:多传感器;数据融合;信号处理;油管;无损检测
  Abstract :In an on - line wall thickness measurement system of oil well tubing using magnetic flux leakage technique , each magnetic sensor can only offer partial information with stochastic noise about it’s environment . The consensus weighted fusion algorithm for the robust fusion of multisensor data is developed. The improved distribution display method
in exploratory data analysis is used to test various sensor’s consensus. Meanwhile ,the simple weighted mean method is in2 troduced to fuse consensus sensor data ,and the robust fused data of multisensor data is obtained as a result . The fusion re2 sults show that the robustness of the measurement system is evidently enhanced ,and the algorithm has specific advantages over some conventional algorithms such as high - accuracy ,and high - efficiency. It is predicted that the algorithm is avail2 able for real - time ,accurate fusion of multisensor data.
Key Words :Multisensor ;Data Fusion ;Signal Processing ;Oil Well Tubing ;Nondestructive Testing
评论(0)
发评论
下载排行榜
