Atmel低功耗的2.4 GHz无线电收发器AT86RF230
消耗积分:0 | 格式:pdf | 大小:1196KB | 2014-03-03
陈贝贝
分享资料个
  This single-chip radio transceiver provides a complete radio transceiver interface between the antenna and the microcontroller. It comprises the analog radio transceiver and the digital demodulation including time and frequency synchronization, and data buffering. The number of external components is minimized such that only an antenna, a crystal and four decoupling capacitors are required. The bidirectional differential antenna pins are used for transmission and reception, so that no external antenna switch is needed.
评论(0)
发评论
下载排行榜
