在多传感数据的处理过程中,有时要利用多传感器对某一对象进行不同方面观测,针对所获得数据研究观察对象属性。此类问题的本质是判别对象的归属类型,就此问题利用多元统计理论,提出一种简明的判别方法。 关键词: 多传感器; 数据融合; 判别分析 Abstract : During data processing of sensors ,sometime some object should be observed from different aspects ,and the object attribute should be researched through the attainable data. The esscence of these problems is discrimi2 nating the belonging type of the object . A concise discriminatory method is proposed by the multivariate statistical theory. Key words : multi2sensors ; data fusion ; discriminatory analysis
