【安森美】NCS20071-D:3MHz带宽运算放大器
消耗积分:0 | 格式:PDF | 大小:961KB | 2014-07-28
孔令双
分享资料个
The NCS2007 series operational amplifiers provide rail−to−rail output operation,3 MHz bandwidth, and are available in single, dual,and quad configurations。 Rail−to−rail operation enables the user to make optimal use of the entire supply voltage range while taking advantage of 3 MHz bandwidth。The NCS2007 can operate on supply voltages as low as 2.7 V over the temperature range of −40°C to 25°C。
评论(0)
发评论
下载排行榜
