全英版HYM8563数据手册
消耗积分:1 | 格式:pdf | 大小:190KB | 2014-08-08
wang0206
分享资料个
The HYM8563 is a CMOS real time clock/calendar,which provides seconds,minutes, hours,day,date,month, and year information。The number of days ineach month and leap years are automatically adjusted。The clock can operate in two modes: one is the 12-hour mode with an AM/PM indicator,the other is the 24-hour mode。 The clock/calendar is full binary-coded decimal (BCD)。In addition, the HYM8563 contains a programmable clock output,a timer, an alarm, a voltage-low detector。 All address and data are transferred serially via I2C bus and The HYM8563 operates as a slave device on the serial bus。 The built-in word address register is incremented automatically after each written or read data byte。 The HYM8563 is designed to operate on very low power consumption。
评论(0)
发评论
下载排行榜
