应用于检测体液中葡萄糖含量的微生物传感器研究
消耗积分:5 | 格式:rar | 大小:274 | 2009-07-13
王毅山
分享资料个
利用某些微生物代谢过程中产生酶的特点,筛选出能够大量生成葡萄糖氧化酶的地衣芽孢杆菌,并将其固定在Sephadex 100 或海藻酸纳- 氯化钙(载体) 上,首次研制成微生物酶传感器. 它不仅具有酶传感器的所有优点,同时也克服了酶传感器的缺点,使用寿命长,性质稳定,成本低,易于保存等. 通过优化微生物和其代谢所产生的葡萄糖氧化酶的固定化方法和利用葡萄糖氧化酶氧化葡萄糖产生过氧化氢的反应机理,建立了模拟酶(hemin) 催化荧光底
物N , N′2 二腈甲基邻苯二氨(DCM2OPA) 检测体液中葡萄糖含量的荧光传感器.
关键词 微生物传感器,酶传感器,荧光,葡萄糖
Abstract  A microbial based biosensor for the measurement of glucose in serum and urine has been developed. Bscillus licheniformis , a microbial , was used in the cytosensor as the producer of glucose oxidase that are required in the biosensor. The influence of the types of microbes , enzyme immobilizing techniques and the carrier for the enzyme or microbial were studied. The new sensor has the advantages of high stability , low cost and easier preservation. It is the first time to develop a cytosensor with a mimic enzyme catalyzed fluorescence reaction for the measurement of glucose in serum and urine.
Keywords  microbial sensor , enzyme sensor , fluorescence , chemiluminescence , glucose
评论(0)
发评论
下载排行榜
