High-performance 3.3-V EEPROM-based programmable logic devices (PLDs) built on second-generation Multiple Array MatriX (MAX®) architecture (see Table 1) ■ 3.3-V in-system programmability (ISP) through the built-in IEEE Std. 1149.1 Joint Test Action Group (JTAG) interface with advanced pin-locking capability – MAX 7000AE device in-system programmability (ISP) circuitry compliant with IEEE Std. 1532 – EPM7128A and EPM7256A device ISP circuitry compatible with IEEE Std. 1532 ■ Built-in boundary-scan test (BST) circuitry compliant with IEEE Std. 1149.1 ■ Supports JEDEC Jam Standard Test and Programming Language (STAPL) JESD-71 ■ Enhanced ISP features – Enhanced ISP algorithm for faster programming (excluding EPM7128A and EPM7256A devices) – ISP_Done bit to ensure complete programming (excluding EPM7128A and EPM7256A devices) – Pull-up resistor on I/O pins during in-system programming ■ Pin-compatible with the popular 5.0-V MAX 7000S devices ■ High-density PLDs ranging from 600 to 10,000 usable gates ■ Extended temperature range
