小波阈值去噪技术在ECG信号处理中的应用
消耗积分:3 | 格式:rar | 大小:192 | 2009-08-06
杨平
分享资料个
本文采用小波阈值去噪方法,利用了小波变换多分辨率的特点,它对信号具有自适
应性,可以降低消噪算法的复杂程度,又可保证心电信息特征不被丢失。试验表明,该方法能较好地实现心电信号的消噪,同时也适合于信噪比较低的生物信号的处理中。
关键词:心电信号;小波阈值;去噪
Abstract:In this paper,we use the wavelet threshold denoising method which take use of the
multi-resolution feature of the wavelet transform. It has a adaptation characteristic to the signal and not only simplifies the complexity of calculation in the noise rejection method,but also preserves the characteristics of ECG..Experiments show that this method eliminates the noise effectively and could also apply to the biomedical signal processing with lower ratio of
signal-noise meanwhile.
Key words: electrocardiogram; wavelet threshold denoishing; noise rejection
评论(0)
发评论
下载排行榜
