弹道修正引信用电动舵机设计与仿真
消耗积分:5 | 格式:rar | 大小:250 | 2009-08-06
李敏
分享资料个
在研究旋转弹舵机结构与控制原理的基础上,结合弹道修正引信的特点,设计一种适合修正引信的电动舵机。通过对舵机原理的研究,提出了相应的舵机控制方法。之后经仿真研究,结果表明所设计的无刷电机驱动的舵机,在交变载荷作用下,舵机能
确保工作中与弹的相位对准、转速同步。
关键词:弹道修正;舵机控制;仿真
Abstract:Based on the structure and control theory of the spin missile actuator and considering the characteristic of the correction fuze, a electromechanical actuator is designed.
A control method of the electromechanical actuator is discussed by the actuator work theory
researched. Simulation results indicate that the designed electromechanical actuator, which is
driven by a brushless DC motor and is forced by the alternate loading, can ensure the
accuracy of phase compensation and rotation synchronization.
Key words:trajectory correction;actuator control;simulation
评论(0)
发评论
下载排行榜
