4047 CMOS 单稳态、无稳态多谐振荡器
消耗积分:5 | 格式:rar | 大小:85 | 2009-08-08
分享资料个
The CD4047B is capable of operating in either the
monostable or astable mode. It requires an external capacitor
(between pins 1 and 3) and an external resistor
(between pins 2 and 3) to determine the output pulse width
in the monostable mode, and the output frequency in the
astable mode.
Astable operation is enabled by a high level on the astable
input or low level on the astable input. The output frequency
(at 50% duty cycle) at Q and Q outputs is determined
by the timing components. A frequency twice that of
Q is available at the Oscillator Output; a 50% duty cycle is
not guaranteed.
Monostable operation is obtained when the device is triggered
by LOW-to-HIGH transition at + trigger input or
HIGH-to-LOW transition at - trigger input. The device can
be retriggered by applying a simultaneous LOW-to-HIGH
transition to both the + trigger and retrigger inputs.
A high level on Reset input resets the outputs Q to LOW, Q
to HIGH.
评论(0)
发评论
下载排行榜
