本文主要讨论由 DSP 为核心构建的磁悬浮系统,并详细分析控制系统的两个 关键要素:主控器和悬浮驱动器。在设计中,这两部分我们分别采用数字处理芯片 TMS320LV5402 和两象限桥式悬浮斩波器。最后分析了具体数字实现中应注意的问题。 关键词:悬浮系统,DSP,TMS320LV5402,两相限桥式斩波器。 Abstract: Suspension System centered on DSP is discussed in this paper. It also analizes two key factors of the control system-the main controller and the suspension drivers. Digital signal processor chip TMS320LV5402 and two-quadrant bridge suspension chopper are applied to this system,respectively. At last,the paper analizes the problems worthy of consideration in digital implement. Key Words: Suspension System , DSP,TMS320LV5402,two-quadrant bridge chopper
